Home Forums Products Stompboxes How to connect H90 to Friedman IR-D and Zoom A3 Reply To: How to connect H90 to Friedman IR-D and Zoom A3
#183445
    If you are using Pre/Post with both presets, you will not be able to connect the 2nd pickup to the H90 since both presets are being used already.
    My suggestion from before would probably be the best/easiest option if you want both pickups going through the H90.
