Home Forums Products Stompboxes Unclear on Input/Outputs and Insert Routing Reply To: Unclear on Input/Outputs and Insert Routing
#183466
sandchannel
    I was thinking about running it with Dual because it would cut down on latency and (I might be wrong here) it would still pass signal with through the OPUS without a preset being activated. The issue with Insert mode is that I would have to create a patch with nothing activated but the OPUS to get a dry signal.
