Home › Forums › Products › Plug-Ins › Blackhole automation problem with Cakewalk › Reply To: Blackhole automation problem with Cakewalk
#183744
tfruehauf
    I use the plugin, newest update.
    My DAW:
    Windows 10,  64 bit, 32 MB, AMD Ryzen 5
    I run a projekt with many plugins for a full VSL orchestra and all automation works fine except Blackhole.  If I stop the transport and set the cursor manually to a certain position, the value of the automation curve is read. However if I run the project, nothing moves even after I stop the transport it stays at the start value. I think, there is a timing problem, it just doesn’t get the automation values fast enough.
    Thank you for your support,
    Tonio
