Home Forums Products Stompboxes Program out gain problem Reply To: Program out gain problem
#184122
depressor
    If I go guitar > H90 > amp input the program out gain works perfectly. I suppose that having an amp with a parallel effect send/return circuit, the dry signal is always present. The H90 processes only the effect signal because I select the Kill dry, so when I turn down the H90 out gain, it acts on the effect signal only, but the dry signal is there in my amp’s send/return. Is it correct on your opinion? Is there a solution for this problem?
