Home Forums Products Stompboxes WIRING DIAGRAMS H90 DUAL OR INSERT Reply To: WIRING DIAGRAMS H90 DUAL OR INSERT
#184221
croalex
    Ok
    but i don’t understand the internal routing of the H90?
    In first diagram the benefit of a parallel blender is to activate or disactivate the path 1 or path 2.
    I have the possibilitie to mix directly(in live) in my pedalboard the dry signal with the path 1 and 2.
    In the second the same thing,activate or disactivate the two paths with the splitter.
    I always use the external preamp/distortion/compressor/ (never pre post effects of the H90) and the effects i only use in H90 are: chorus/delays/reverbs/pitch.
    In the different two paths i have different effects…example:Filter Pong+Space Time.
    I think for me this configuration works probably in live and in home studio for recording with the Two Notes Torpedo Reload.
    Actualy i have two H9, an old Eclipse and i use a H90 of a friend…but i want to buy one H90.
    If you have a good diagram in a box(H90) to use for my case without mixer,splitter, in stereo configuration…
    See my basic equipement in attached file.
    Thank you and escuse me for my bad English…i am French.
    Alexandre
