Home › Forums › Products › Stompboxes › H90 Dual Routing Levels › Reply To: H90 Dual Routing Levels
September 1, 2024 at 10:46 am
#184597
Same outcome Thank you and will report back.
Can confirm that it appears it was the internal send/receive settings on the Katana; both were set at 100 instead of default 50. Although Algorithms 1,2 in series on path B seem really quiet. When I set them as parallel on path B, all is good. Could be a function of the specific Algorithms? I’m using a delay and chorus.
