Home Forums Products Stompboxes H9 Powered by Pedaltrain Powertrain 1250 Reply To: H9 Powered by Pedaltrain Powertrain 1250
#184615
    Sorry, I can’t give you a definitive answer for this since it is an older, discontinued power supply and the user manual is not very clear. You may be able to power an H9 using one of the outlets from the shared 500 mA group. You will need a power cable that provides a center positive connection.
    You would probably be better off using a newer power supply, but you may be fine using these.
