Home › Forums › Products › Stompboxes › H90 Dual Routing Levels › Reply To: H90 Dual Routing Levels
        September 3, 2024 at 11:24 am
        #184617
Glad you figured out the misconfigured effects loop.
Although Algorithms 1,2 in series on path B seem really quiet. When I set them as parallel on path B, all is good. Could be a function of the specific Algorithms? I’m using a delay and chorus.
Are both paths set to the same operating level? Every Preset has In/Out gain controls that may not be set to zero based on the way the preset was designed. Also, every preset has a Mix control that when not set to100 will introduce dry signal that in parallel will have an additive effect which may through things off.
