Home Forums Products Stompboxes MicroPitch, Expression Pedal, Device Manager Reply To: MicroPitch, Expression Pedal, Device Manager
#184666
joecozzi
    Hi Patrick,
    Thank you for your kind words.
    Is it possible to map the expression pedal to a specific parameter in the software, alone, without having to mess with the pedal directly as well? And if so, how would I go about that?
    Yes. In EDM (Eventide Device Manager), click on the dot just under the knob you want to program. You will see an arc appear with blue and yellow endpoints. Blue is the starting position, yellow is the end position. Move these around to determine the range of control you want. It is possible to reverse these. In other words, your heal position could be the start point and the toe position your end point; the arc will have a yellow color indicating a sweep in the opposite direction. Once you have made your assignments, be sure to click the Save button to store your settings.
