Home › Forums › Products › Stompboxes › MicroPitch, Expression Pedal, Device Manager › Reply To: MicroPitch, Expression Pedal, Device Manager
#184670
joecozzi
    how do I adjust the mix of the delay separately, i.e. the volume amount of the delay without changing the amount of detune? Is that possible? …Or are they all coupled together?
    By design, they are coupled together. The Mix parameter affects the detune and delays together. Only way around this is using a different preset for just detune and another with both detune and delay. I understand it’s not optimal but there’s no way to control the mix of both effects individually.
