Home Forums Products Stompboxes Bypass Parallel Insert Question Reply To: Bypass Parallel Insert Question
#184683
    Yes, it is by design that bypassing the insert will always pass the signal through. There is no logic for it to mute the insert when it is in parallel, but that is a good feature request and we can look into adding this behavior in a future update.
    If your delay pedal is in kill dry, you can try bypassing the delay pedal and that should mute the signal.
