Home Forums Products Stompboxes Switching Power Supply for H90 Reply To: Switching Power Supply for H90
#184713
joecozzi
    I’m looking for a higher quality power supply for the sometimes noisey H90. I’m curious if this will fix its USB woes.
    If the noise happens only when you connect the USB cable, it’s most likely due to a ground loop issue in the studio. Making sure all devices share the same power outlet might help fix the problem.
