Home Forums Products Stompboxes Changing the Programs Route Type Reply To: Changing the Programs Route Type
#184747
    Programs that are created in Insert mode cannot be used in Dual mode, and vice versa.
    You’ll need to recreate the programs in whichever mode you are using.
    Can you be more specific about the other issue you describe? If you change your routing back to dual mode you should see all of the lists and programs that you have been using in dual mode.
