Home › Forums › Products › Stompboxes › Changing the Programs Route Type › Reply To: Changing the Programs Route Type
#184750
gustavo.automacao
    “Programs created in Insert mode cannot be used in Dual mode, and vice versa. You’ll need to recreate the programs in the mode you are currently using.”
    Replying: I noticed this as soon as I made the change. Besides being a musician I’m of technology market, work with solutions for special weight, in technical segment. I am claiming that this is a problem, because the programs (which is formed by “sub single effects”), (Logically) cannot be linked to the route mode. It makes no sense to condition the effect on the route.
    I know that some parameters of programs specifics how the route occurs, but I think this can’t be a problem when I change the route mode. I understand the pedal software/firmware (or control) not being able to auto adjust/configure the route properly in the other format, but it needs to show a default route and allow me to open the program and change it however I want.
    If I buy programs, or get from someone, I’m have to be free to change the way I use it. It doesn’t make sense to have to recreate 26 programs or 52 “single effects”, just because their routing is different from the ones I created.
    Please discuss this with your development team, the equipment is too expensive to not allow this small adjustment.
    – “Can you be more specific about the other issue you describe? If you change your routing back to dual mode you should see all of the lists and programs that you have been using in dual”
    Replying: : When switching back to Dual mode, the presets in Dual mode appear as expected. This doesn’t seem to be an issue; the presets are displayed correctly if you choose the appropriate mode.
    Thaks so much!
