Home Forums Products Stompboxes Recommended expression pedals for H90 Reply To: Recommended expression pedals for H90
#184778
    This seemed like an appropriate thread for a necro-update.  Nektar NX-P expression pedals.  They were among a pile of switching & pedal action units that I bought, with the sole intent of hacking them up for custom projects.  $20 USD, everywhere I’ve seen them.
    It took a few tries at the H90 Calibration to get a consistently smooth travel.  Always with the side trim knob fully towards Toe.  At one point, NX-P SW1 position maxed at a 0-94 range, with SW2 0-100.  Yet SW2 position had about 50% of the parameter range confined to 1/4 to 1/3 of the treadle travel (+/-; parameter dependent average).  I settled back on ‘polarity’ switch position 1 in the NX-Ps.  Now it’s full range 0-100 (go figure).
    Tighten the axis locking nut a bit for the loose travel.  I wouldn’t rely on this pedal to hold a fixed wah-type position.  Maybe a half-inch longer & narrower than an EV-5.  The rubber feet can peel off fairly easily for pedalboard mounting.  I like the grip feel on the treadles themselves.  The shell is plastic all around, understandably feeling / looking cheaper than an EV-5 build.  It’ll come apart easy enough to get at the guts, or swap the attached TRS cable.
    No idea how these will hold up for longevity.  For roadworthiness & general live abuse, my EV-5s & Reflex will stay put.  But for home use, circuit-bending, or sheer cost considerations, NX-Ps function just fine.  I have no affiliation with anyone; just a PSA on one bargain option.  You can buy nearly 4 NX-Ps for the price of an EV-5, and you “need” a two pedal minimum for the H90.
