Home › Forums › Products › Stompboxes › Firmware Uploads are failing › Reply To: Firmware Uploads are failing
        September 18, 2024 at 12:21 pm
        #184826
Sorry for the issues you are having.
To clarify, only 5 presets can be accessed on the pedal itself, but when you use MIDI or connect to EDM, you should see the additional presets without needing to update. What happens when you power on the pedal and connect to EDM without attempting to update? Do you only see 5 presets?
