Home Forums Products Stompboxes Firmware Uploads are failing Reply To: Firmware Uploads are failing
#184863
    Thanks for the information. Can you please try using the pedal in update mode and trying again? Power on the pedal while holding the Vibe footswitch and LED button, and then use EDM to attempt the update again.
