Home Forums Products Stompboxes Firmware Uploads are failing Reply To: Firmware Uploads are failing
#184882
    Just to make sure, when you connect your Blackhole to EDM are you able to update the firmware on that pedal with no issues? Can you try disabling any antivirus programs you may be running and seeing if that makes the Riptide update work?
