Home Forums Products Stompboxes Firmware Uploads are failing Reply To: Firmware Uploads are failing
#184946
peteycorn
    I re-downloaded and installed EDM, then ran EDM, chose the Blackhole, checked for updates, and ran the latest update.. Then I got the same results that I’ve been getting when trying to update the firmware of the two Riptides.
    Maybe my computer isn’t able to run the firmware updates :/  (see attached for results, and computer specs)
