Home › Forums › Products › Stompboxes › unexpected behaviour of aux switch mapped to ‘perform mode’ › Reply To: unexpected behaviour of aux switch mapped to ‘perform mode’
September 30, 2024 at 10:50 am
#184992
Is there another method to assign an aux pedal to toggle between the internal foot switch functions FS1-3 and FS4-6? Or is it the idea that you can tap with your foot on the select and perform and select knob if you want to toggle?
There is no assignment for toggling between pages of Perform mode. You are correct, users need to step on the Peform knob to switch pages.
they don’t seem sturdy enough for that
As long as you use the same pressure you would use for any normal footswitch, they can handle it.
