Home Forums Products Stompboxes Mixing Link Auxiliary Input Physical Specifications Reply To: Mixing Link Auxiliary Input Physical Specifications
#185186
joecozzi
    What type and size “mini-plug” does the input port require, and can it accept a “standard” “TRS” plug? rather than a “TRRS” mini-plug
    Hi Synergist,
    The MixingLink’s Aux input accepts a standard 1/8″ (3.5mm) input for simple stereo playback of audio from an external device. The only time a TRRS connector is necessary is when you wish to direct audio to an external device; for example, if you use software like IK Multimedia’s Amplitude on a mobile device. The TRRS connection takes care of audio into the external device and back to the MixingLink through one cable.
