Home Forums Products Stompboxes H90 – chord movement challenge Reply To: H90 – chord movement challenge
#185220
    I toyed around with this some, this past weekend.  The initial solution was shifting the middle voice / Pitch A(?) a degree using a HotSwitch – momentary or latch & unlatch.- for just the 3rd chord.  That can just as easily be controlled by an Aux switch, expression pedal, or MIDI (whatever’s handy).
    A temporary change of Scale may also work, but I think the playing & timing might have to be tighter.  I don’t know that this behavior is ‘wrong’ in a G Hungarian (minor) scale.  I’ll know more when I can confirm with the Scale Degree maps I put together (originally, for the PitchFactor).
    Something is bothering me about the component intervals of that chord progression you’ve spelled out.
