Home Forums Products Stompboxes H9: Set tempo with midi CC? Reply To: H9: Set tempo with midi CC?
#185309
joecozzi
    I’ve found that midi clock works which is fine but not relevant in my case.
    Can you elaborate on what you’re trying to do? How do you want to control BPM, by sending predetermined values or some type of expression?
    I haven’t figured out a way to set the BPM tempo using CC. I’ve found that midi clock works which is fine but not relevant in my case… Is direct Midi CC control of tempo simply not there or I just didn’t find it?
    No, there is no programmable parameter to directly control tempo. That’s really what MIDI clock is for.
    In order to set a BPM using MIDI, the H9 should be configured to receive MIDI Clock. Your controller, whether it’s a DAW or a standalone foot switch controller, should have a specific command to send a MIDI BPM on press. For example: my Morningstar MC6 MkII has a command for MIDI Tap Tempo, which you have stated you do not want to use, and a separate command for setting a specific BPM with a button press. If I’m controlling BPM from a DAW, the H9 simply follows the MIDI Clock of the session.
    If you do not use MIDI Clock, it is possible to control tempo by simply assigning a CC# to control the parameters in question. On H9 Control, if you click on the Pedal tab > MIDI Settings > Assign MIDI CC Messages, the “Set Parameter 1…10” options correspond to each knob of the algorithm. For example, say you are using the Digital Delay algorithm,
    Set Parameter 1 controls Mix
    Set Parameter 2 controls Delay Mix
    Set Parameter 3 controls Delay A time
    Set Parameter 4 controls Delay B time
    Set Parameter 5 Feedback A
    Set Parameter 6 Feedback B
    Set Parameter 7 Xfade
    Set Parameter 8 Mod Depth
    Set Parameter 9 Mod Speed
    Set Parameter 10 Filter
    If you program a CC# for “Set Parameter 3” to control the Delay A time, you will be able to either send a CC# along with a value to achieve a specific tempo in milliseconds if Tempo Mode is set to OFF, or you can send a value to set it to the appropriate subdivision if Tempo Mode is ON. In the latter case, the BPM will be determined by the predetermined tempo, or if MIDI clock is on, whatever clock it’s receiving at the DIN MIDI input.
