Home › Forums › Products › Stompboxes › H9: Set tempo with midi CC? › Reply To: H9: Set tempo with midi CC?
October 10, 2024 at 11:06 am
#185317
Hi, thanks.
In this case the H9 is CC-controlled by a Nord Modular G2 synthesizer and this is then tempo synced to an Ocatrack using midi clock. However midi clock can not be mirrored on the output of the synthesizer only on midi thru but then I wouldn’t be able to control the other H9 parameters.
I found a workaround sending an automatic tap from the synthesizer on midi cc. Other solution would be to merge midi out and thru to the H9.
In my case best would have been to simply send a midi CC specifying tempo for each patch.
