Home Forums Products Stompboxes H90 looper not working…. Reply To: H90 looper not working….
#185342
joecozzi
    Let’s say you have the Looper in Preset B. Below, I’ve listed the looper performance controllers that can be mapped to your MIDI controller using CC numbers. On your MIDI Controller assign CC numbers to footswitches so they correspond to the actions you want to control like Record, Play, Stop, etc. Make sure your controller is sending messages on the same channel as the H90 – default Channel 1. In my example, I have made the following assignments:
    CC17 – 1-Button Looper
    CC12 – Record – CC12
    CC13 – Play
    CC14 – Stop
    CC15 – Undo/Redo
    CC16 – Erase
    Important: For the MIDI Controller to behave like a momentary switch, it’s necessary to program two commands per switch:
    • On Press – Send CC# with value 127
    • On Release – Send CC# with value 0 (zero)
    To program controller change numbers to looper functions on the H90:
    1. Press PERFORM to enter Perform mode
    2. Press the B LED button to enter the Performance Parameter Mapping menu for Preset B.
    3. With the first quick knob scroll through the list of parameters until you see Record.
    4. With the second quick knob set that to learn.
    5. Press a footswitch on your MIDI controller so the H90 senses the correct CC#
    6. Repeat steps 3-5 for Play, Stop, Undo/Redo, Erase, and 1-btn loop, if you want.
    7. Once you’re finished making assignments, press PERFORM to exit the mapping menu. Don’t forget to save your Program.
    Now you have full control of the looper via MIDI.
