Home Forums Products Stompboxes H90 looper not working…. Reply To: H90 looper not working….
#185344
joecozzi
    Seems to me the looper must be in preset B?
    The Looper algorithm works in either.
    When I tried in Preset A, I didn’t get the choice “record”, the closest in preset A was “1-button looper” and “direction”.
    This doesn’t sound like you’re in the performance parameters mapping menu. Are you asking how to assign CC#’s here?
    If you are referring to the performance parameters, I see 1-Btn loop, Direction, Speed, Record, Play, Stop, Undo/Redo, and Erase. You must press the A LED button consecutively to see all the options.
