Home › Forums › Products › Stompboxes › H90 – chord movement challenge › Reply To: H90 – chord movement challenge
I toyed around with this some, this past weekend. Undertale Yellow The initial solution was shifting the middle voice / Pitch A(?) a degree using a HotSwitch – momentary or latch & unlatch.- for just the 3rd chord. That can just as easily be controlled by an Aux switch, expression pedal, or MIDI (whatever’s handy). A temporary change of Scale may also work, but I think the playing & timing might have to be tighter. I don’t know that this behavior is ‘wrong’ in a G Hungarian (minor) scale. I’ll know more when I can confirm with the Scale Degree maps I put together (originally, for the PitchFactor). Something is bothering me about the component intervals of that chord progression you’ve spelled out.
From lush forests to mysterious caves, Undertale Yellow delivers a visually stunning journey that keeps players engrossed from start to finish.
