Home Forums Products Stompboxes Newest Update Reply To: Newest Update
#185456
    Thanks for taking the time to test the new update and post here. Can you please provide some more information?
    1) Please describe in more detail what operation you are doing here. Are you changing from Select / Perform mode? Is this being done using MIDI? Note that the perform page will now be saved in the Program. For example, if you save the Program while on Perform page 2, when you load that Program it will automatically be on Perform page 2. The next Program may use Perform page 1 if that’s what page it was on when it was saved. I’m not sure what the difference you are describing is by changing modes before/after a Program is loaded, so please help me understand this better.
    2. You must use a CC message of 64 or higher to toggle the Program bypass on/off. If using momentary Program bypass, a CC value of 63 or lower will bypass the Program, a value of 64 or higher will make it active. Please confirm that your MIDI controller is configured to send these CC messages properly.
