Home Forums Products Stompboxes H90 & Friedman IRX – best setup? Reply To: H90 & Friedman IRX – best setup?
#185602
joecozzi
    In Dual routing, it would seem I can only have 1 Algo before and after the pre-amp, so would I loose the use of those great postFX programs in that setup?
    It is true, you only have two Presets total; so, they can be configured as two presets in Path 1 (Pre), or two presets in Path 2 (Post), or one preset on each path. These can be stored on a Program basis.
    I could setup the IR-X as an insert within the H90, but when I did that and disabled the unit all my tone disapeared (as expected).
    In the System Menu > Global > P Bypass, you can set this to “AB Only,” and when you bypass the Program it will keep your insert loops open. Make sure you’re on the latest software version of the H90.
