Home › Forums › Products › Stompboxes › Boss OC3/5 Octave Range Setting › Reply To: Boss OC3/5 Octave Range Setting
October 25, 2024 at 10:07 am
#185766
You can try Sculpt in Stereo Mode – Split. It won’t be a perfect match, but you can independently post-process each channel downstream.
Adjust the Crossover Frequency between Low & High Drive (with or without much drive added in either band). Tweak the Band Mix to taste.
Bonus wah via envelope or expression, if desired.
