Home Forums Products Stompboxes External control of Quickknob parameters Reply To: External control of Quickknob parameters
#186139
joecozzi
    Hello tiresias,
    I want to control the mix level of each algorithm independently but only have one expression pedal…Is it possible to map three different mix levels, eg. low, medium and high to three different foot switches on the MC6 Pro for the reverb algorithm whilst leaving the expression pedal free to control the mix level for delay.
    Yes.
    Can this be done for instance with CC messages with different values for the mix levels?
    Yes, that’s one way to do it but the H90 offers this type of control using Hotswitches in PERFORM mode. You don’t need to take up switches on your MC6 Pro. Check this out: https://youtu.be/5y14LwN9oAk?t=3198&si=4ZhBLPAsVH3Bumrj
    I’m a bit confused by the release notes for the latest firmware release regarding Perform Overlay. Is this something that has to be activated? I can’t see any difference on the screen between this release and the last. Maybe I just didn’t spend enough time with the prior release to notice any difference.
    These perform overlay features will only be present when engaging functions that have been mapped from the Performance Parameter Mapping menus. If you haven’t mapped any Performance parameters to external switch or controllers, you won’t see the overlays.
