Home Forums Products Stompboxes External control of Quickknob parameters Reply To: External control of Quickknob parameters
#186236
tiresias
    Yes I was thinking of something like a sweep through delay time values but doesn’t sound possible with a switch. I think the Mash switch was a pressure sensitive expression device. I remember a preset on the H9 with delay values preset for an expression pedal which was quite fun. It might have been lost lunch or something like that.
    Next question then, Can an expression pedal be switched between mappings?  E.g. is it possible to switch an expression routing from say programme mix level to an algorithm delay tempo subdivisions. A longshot I know. Maybe a second expression pedal required.
