Home Forums Products Stompboxes Mix knob resolution in H90 Reply To: Mix knob resolution in H90
#186251
transmetropolitan
    Thanks for replies.
    The program mix point is a good one. It does impact on both of the slots however, so if one wanted to use the other slot for something at 100% wet it wouldn’t help for that use case. But the vast majority of the time this will give me a good practical solution.
    The Kill dry point is another very good one & I’ll definitely use lists to do that.
    Appreciate your time to respond. Thank you.
