Home Forums Products Stompboxes Update H90 firmware Reply To: Update H90 firmware
#186429
    I just responded to your support ticket but I’ll post my answer here as well for other users to find:
    For the Perform Mode command, this was also changed so that users can scroll through the perform mode pages that same way that pressing the Perform Mode knob will do.
    When you toggle back and forth from Select and Perform mode, it will remember the last page you were on in Perform mode. You can also save which perform mode page is remembered when you save a Program.
    So, if you stay on Perform page 1 and toggle between select/perform, you should find that you always end up on perform page 1. It may be that you have some programs saved that are remembering to jump directly to the perform page 2.
    Please try loading a program, going to perform page 1, and then saving the Program. After that, you should find that you can load the program and toggled select/perform mode, and it will remain on page 1.
