Home Forums Products Plug-Ins H9 bundle and mod wheel Reply To: H9 bundle and mod wheel
#186513
jeffschumacher
Sorry to hear you’re having trouble. It sounds like you are using an instrument track with an H9 plug-in as an insert, correct? Unfortunately, it seems that incoming MIDI information is routed only to the instrument slot on an instrument track, and not downstream to the plug-in inserts.
I have found that an easy work-around for now would be to create a separate MIDI track, route that track to the H9 plug-in instance, and record/monitor enable both tracks.
Let me know if this helps.
