Home › Forums › Products › Stompboxes › How to routing sometimes stereo, sometimes we/dry › Reply To: How to routing sometimes stereo, sometimes we/dry
There are no effects connected to the Atom switcher running in stereo, but I could use it, just that I’m trying tu use the H90 independently because I can control the H90 via MIDI, and that way I can save the atom loops for analog pedals.
I don’t know if it was clear what I’m trying to achieve, but to be more precise I’ll give you some examples:
Let’s say that in the first example I would like to use the Tape Delay algorithm in stereo on both amps and the Plate Reverb algorithm in stereo on both amps.
In the second example I would like to use both algorithms just in one amp. Let’s say the Pitch Crystals algorithm and the Shimmer algorithm, both algorithms on Amp1, and no algorithm on Amp2.
In the third example, I would like to use, say, the Even Vibe algorithm in stereo on both amps, and the Spring Reverb algorithm only on Amp1.
And one last example that I forgot to mention, would be to use one algorithm on Amp1 and another algorithm on Amp2. Let’s say the Chorus algorithm on Amp1, and the Ultratap algorithm on Amp2.
I hope it was easier to understand this way. I think there is a way achieve this, but I don’t know which the correct way is.
Thanks for your help.
