Home › Forums › Products › Stompboxes › H90 Preset Bypass UI › Reply To: H90 Preset Bypass UI
#187625
    You can assign your MIDI controller to the active/bypass states of Presets A/B by making a global mapping. For example, you can make it so CC1 will always toggle the active/bypass of Preset A, and CC2 always toggles the active/bypass of Preset B.
    Information about global MIDI mapping on the pedal or H90 Control can be found in the manual below:
    https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/system-menu/midi.html
    https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/h90-control/system.html
    If you update your pedal to the latest software, you should see a popup for the active/bypass state when you are in Select Mode.
    Let me know if that helps.
