Home › Forums › Products › Stompboxes › Source Audio Reflex to H90 MIDI issue › Reply To: Source Audio Reflex to H90 MIDI issue
January 10, 2025 at 9:51 pm
#187647
Also just tried to set up an expression control in H90 through MIDI using Reflex just in case (I use TRS expression usually), seems to work fine, used following settings
Reflex:
Digital Out 1 (d1)
Chan 4 (H90 channel)
Type 7 (CC#7)
H90:
Preset Exp Pedal Flange
Changed Control Source from Exp Pedal to MIDI CC CC#7
