Home Forums Products Stompboxes Tremolo Reply To: Tremolo
#187683
joecozzi
I would suggest working with one algorithm at a time, so to start, I would bypass one algorithm to really dial in the other. What does your routing presently look like? Is it series or parallel routing. You can see it by pressing the Routing LED button. I recommend using series routing so you’re not accidentally routing a copy of your signal next to something one of the effects.
