Home Forums Products Stompboxes Tremolo Reply To: Tremolo
#187688
joecozzi
Yes, that’s normal because a reverb by its very nature uses several delayed copies of the signal to prolong the sound, so it maintains the essence of the original signal going eventhough it may be 100% wet. If you want to experiment with a reverb in parallel, I would suggest running the reverb 100% wet and lowering, or controlling the volume of the reverb using its output gain. You’ll find that at lower output gain settings you begin to hear a more pronounced tremolo effect. When using it in series, how about putting the tremolo after the reverb? Then, set reverb’s Mix setting to taste to get a good balance of trem and verb all in one.
