Home Forums Products Stompboxes H90 CV Input Range Reply To: H90 CV Input Range
#187856
AnikaLaughlin
    @ Block Blast What does the H90 do with control voltages over 5V? I’ll need to build a thing to scale the CV range of my modular (0-10V) but want to be sure I won’t damage anything if the 5V upper range limit is exceeded.
    Thanks.
    – Jim
    I think you could use a voltage divider or a protection circuit to limit the input voltage to around 0-5V before feeding it to the H90. Could that be correct?
