Home › Forums › Products › Stompboxes › Recommended expression pedals for H90 › Reply To: Recommended expression pedals for H90
Quick update from me on the Mission SP-25L-Pro Aero. Basically the SP-25L has a latching toeswitch which doesn’t work with the H90 as the H90 requires a momentary toe-switch. It’s taken me the best part of a year to figure this out – and thanks to the Eventide support team! Now I have figured out that the SP-25L won’t work with the H90 I’m pleased to share my workaround. What I did was to unscreww the Mission baseplate, unscrew the latching footswitch and unplug it. Then I got my soldering iron out and installed a momentary footswitch inside the Mission Aero. It works a treat. In fact, I even kept a white LED and a 220 Ohm resistor in the circuit so that the baseplate lights up when the momentary switch is activated!
