Home › Forums › Products › Stompboxes › Eventide H90 MIDI PC Change and Bypass at the same time › Reply To: Eventide H90 MIDI PC Change and Bypass at the same time
February 3, 2025 at 12:19 pm
#187999
We are aware that there is an issue with this use case and are working on a solution. Previous versions of the firmware should allow you to use the simultaneous PC+CC messages, or if you use Program level active/bypass mappings (not global active/bypass mappings) then that should work as well.
I’d be happy to help you with this further if you email support@eventideaudio.com.
