Home Forums Products Stompboxes Eventide H90 MIDI PC Change and Bypass at the same time Reply To: Eventide H90 MIDI PC Change and Bypass at the same time
#188001
stroboscapes
Just to comment that the Program level active/bypass does not work when sending PC+CC messages. I have tried it several times. No CC messages get recognised after sending the PC. I will contact support.
Apparently it should work with firmware 1.8.6. I’ll try downgrading it and confirm.
