Home › Forums › Products › Stompboxes › Eventide H90 MIDI PC Change and Bypass at the same time › Reply To: Eventide H90 MIDI PC Change and Bypass at the same time
February 4, 2025 at 1:03 am
#188004
I note that ‘previous versions of the firmware should allow you to use the simultaneous PC+CC messages‘. Is there a previous version of the firmware that will do this that does not also have the issue where presets would load with the wrong delay time (AUD-74364)?
