Home › Forums › Products › Plug-Ins › Volume Compensation for Crushstation Plugin › Reply To: Volume Compensation for Crushstation Plugin
#188161
tlongabaugh
    Hey Demious,
    Yes, the Output Gain affects both the dry and wet signals. I understand that this is not particularly ideal.
    Would using the DAW-provided Bypass solve the issue for you? This would completely bypass the plugin and thus no Output Gain would be applied to the dry signal.
    -Tom
