Home Forums Products Stompboxes H90 MIDI solutions Reply To: H90 MIDI solutions
#188181
ryq
    I think, maybe, you didn’t understand.
    I just need to know if the H90 can send and receive MIDI simultaneously via USB.
    Or, if the H90 can only receive MIDI through USB but not also send it; could I receive the MIDI via USB while also generating and sending MIDI via 5-pin din?
    As for your questions:
    What is your pedal that is sending MIDI?
    The Sonuus Voluum.
    What MIDI channels are you using?
    Sort of irrelevant. I want the MIDI CC message that is sent from the Sonuus to go to and then thru the H90 to other pedals downstream WHILE being able to generate MIDI PC messages with the H90 itself to send to other pedals downstream.
    They can all be on the same channel. The goal is to use an incoming MIDI CC as expression for the H90 while doing two additional things: 1. Also use that CC message downstream as MIDI expression for other pedals and 2. Still use the H90 to send PC messages to other pedals downstream so that they change presets when I change presets on the H90
    <span style=”font-size: inherit;”>If you do not want certain devices to receive certain MIDI messages, it is best to assign each device to a different channel, and then use the channel configuration to determine which device receives what messages.</span>
    This is not a goal that I have for my setup.
    Trying to utilize the H90 as a MIDI controller for other pedals, while keeping from having it hogging the CC signal from the other MIDI expression pedal (Sonuus Voluum). The Sonuus has both 5-pin din and USB MIDI out.
