Home › Forums › Products › Stompboxes › Transmitting MIDI via USB with H90 › Reply To: Transmitting MIDI via USB with H90
February 16, 2025 at 2:37 pm
#188189
If the H90 is being controlled via USB, the only messages it will pass on via DIN MIDI are program changes, not CC messages. If the H90’s MIDI output is set to transmit and you initiate commands from the H90 and aux switches and expression pedals connected to it, you can transmit PC and CC messages from the H90.
