Home › Forums › Products › Stompboxes › H90 Looper › Reply To: H90 Looper
I… in perform mode, I have to scroll to the third page of footswitch assignments to get to the REC PLAY STOP. Can I get these to be assigned to the first page?
No, these were ‘added access’ pages, locked to pages 3 or 4. To date, anything beyond the standard 2 page flip is unique to the Looper algorithm.
… Seems odd the way it is setup and I can’t seem to see how/where in the H90 Control software to set these. I see FS1-6 parameter settings, but that doesn’t seem to be getting me what I need for the looper controls.
It had me scratching my head at first, too. I don’t believe there is a way to map those in H90 Control.
I assign REC PLAY STOP on the pedal itself. In Perform Mode, press the corresponding LED switch below each page 3/4 Looper command, and dial the Quick Knob up to your desired AUX or MIDI switching command.
I’m no big fan of Global mapping assignments, with one exception: a mapping to Perform Mode. I’ve found it invaluable for switching Perform pages, especially when using two Looper instances. CC#4 has become my permanent page-turner.
