Home Forums Products Stompboxes Eventide H90 MIDI PC Change and Bypass at the same time Reply To: Eventide H90 MIDI PC Change and Bypass at the same time
#188925
stroboscapes
    Just an update: H90 edit now doesn’t work. It only tells me that a software update for the H90 is required and won’t let me into the preset editor. So basically I have to chose if I can use the pedal the way I intended, or if I want to use the editor.
    This makes it somewhat useless, doesn’t it?
